Hi all, we have been back and forth speaking to various trades to finalise how to go about reducing the water ingress that comes through the coal hole and kitchen. As a background the front part of the property is on a slope facing the front garden. There is a coal hole just under the front steps and a kitchen right next to the coal hole one of the kitchen walls is covered up to 2 meters high by the soil of the front garden externally. When we stripped back the walls of the kitchen the wall that is next to the coal hole and covered externally by the front garden soil was wet (picture below is from this weekend after 2 months without any plaster internally). No just damp but wet. We started with big plans to retain the coal hole (marked as storage in the diagram below) but money got in the way and decided to sacrifice the space by building a masonry wall between the coal hole and the kitchen and close it off from the rest of the house.
We still need a solution though for the kitchen wall that is essentially under ground. The options that we are considering at the moment are:
1) to install a very deep French drain outside the wall that is underground and hope that by improving external drainage we will get humidity down to levels that we can manage with good ventilation
2) to install a French drain as explained above and add a waterproofing membrane externally on that wall such as a Delta membrane to improve our chances of getting as less water ingress as possible especially if in the long term there is a chance that the French drain might fail
3) to do number 1 or 2 above but not just on that wall but the whole perimeter of the coal hole
We got a plumbing company that specialises in external draining to do the works. Does anyone know if we also need to involve an engineer to design the drain (if depth of the drain is a consideration)? I have been reading different opinions online and don't want to overcomplicate things if this is a straightforward task that an experienced tradesman will be able to do. Does anyone have an experience with either of these options that you can share?
