MdB said:Low voltage lighting systems may be safe to touch due to the reduction in voltage. However, for the same power output, the current has to go up by the same ratio that the voltage has gone down.
This means that the cable will have to have a larger copper core than T&E.
As an example, a single 240V 100W bulb requires 0.42A to drive it. Five 20W halogens on the other hand, running at 12V requires 8.3A to drive them.
Due to the high currents, it is important that there isn't any danger of shorts / weak joints due to the possibility of over heating leading to fires. I would be cautious in using enamelled wire for this reason.
