We bought an end of terrace Victorian property last year and have gradually been doing renovations. Most of the work does not actually relate to issues caused by the age of the house, but rather remedying unsuitable/low quality repairs by previous owners.
We have managed to obtain documents relating to a chemical damp proof course treatment carried out almost twenty years ago. The damp proof course has been installed on all walls with an exterior face (given it’s an end of terrace this is all but the partition wall), to a height of around 60-100cm. Inside the property, to above where the chemical damp proof course has been inserted, there is then a very hard dark grey render acting as the initial layer of plaster. This looks rather cement like to me, and the documentation refers to ‘drywall chemical plastering’ that contains ‘drywall salt retardant additive’.
The property has no current dampness (all moisture readings have come back fine) and there does not appear to have been excessive damp problems at any time. The underfloor area around the bay window seems to have suffered slightly at some point in the past (presumably before this damp course was added), but quite why such an extensive damp proof coursing was added seems a slight mystery.
We have been trying to maintain/improve the breathability of the building using lime plaster and clay paints, and so the presence of chemicals/possible cements that restrict breathability makes me nervous. My questions are:
- Does this sound like an appropriate and well-executed treatment that is providing benefit?
- Is it likely to present a concern/problem for the future?
- Or is this a case of if it isn’t broken don’t fix it (i.e. everything is dry so leave well alone).
