Hi
I am in the process of renovating a 17c listed stone built cottage and as part of the renovation and because of the grade 2 listing I will be laying a limecrete floor. I have just started digging the floors to the required levels and it is apparent by the amount of stone that is in the floor that this is likely to be supporting the walls. My question’s are 1. Am I correct in assuming that the stone in the floors are supporting the walls. 2. If they are, then is it still OK to dig the floors as long as I taper the digging rather than dig straight down. Any suggestions/advice with this would be appreciated. I should also say I’ve stopped digging while I check this out!
Rob
Rob
