I've just bought some engineered oak flooring which I'm planning on putting in our kitchen and dining room on top of a concrete floor. Having just taken up the previous laminate/chipboard/DP/polystyrene floating floor combo which was down in the dining room i discovered a smallish area of mould on the chipboard near the back door. I think this is probably due to condensation rather than water ingress, although I have to admit I'm a bit confused about that bit.
Anyway, I've opted for the engineered rather than the solid wood option to hopefully help avoid/reduce potential warping problems but I still appear to have 2 potential options for laying this floor :
1. DP membrane and insulating layer (it gets mighty cold in our house in the winter), then glue the T&G boards together as a floating floor.
2. DP membrane and insulating layer, then screw battens down to the concrete floor and secret nail the boards on top. The main thing that puts me off this is the increase in the floor height as I guess I'll need battens at least 15mm thick?.
Does anyone have any experience of either of these methods, or advice either way?
