sarahj
- northumberland
Hi,
I have a week to decorate my 6 year old daughter's bedroom. I have emptied it, taken up the carpets, and the fun bit: pulling off the wallpaper - it came off in sheets, all of it!. However, a small area directly under the very low window ledge pulled off the plaster as well - right down to the stone. It is an area of about 18" by 18", and is the outside wall. (Sadly all of the other walls are modern gypsum).
I would very much like to patch this with ready made lime plaster - can I buy it from builders merchants and will I be able to do it along with the rest of the wallpapering?
I currently have her camped down in our bedroom while my husband is away for the week and the room is so small there is not really the space to do it on his return (we would both have to climb over her to get to our bed!)
I live in rural Northumberland so on the one hand I would expect local builders merchants to understand and supply lime products but on the other hand I expect that if they do local builders probably mix their own from scratch.
Thank you,
Sarah
Thank you,
Sarah
