Feltwell
- Shropshire, England
There was I yesterday, convincing the neighbours that I really do need certifying, wandering around outside in a torrential downpour with an umbrella looking up at the roof and checking the guttering and downpipes are all functioning OK, when I noticed the ground was sparking - distinct sparks, and little puffs of smoke, coming from one spot.
So today, knowing that the mains cable that comes into the house is not there, I gingerly dug up said spot and found what I believe is the culprit. The previous people here had Sky TV and telephone, what I've found is the underground cable to serve that, which has been severed.
Having deferred to the Great God of Google, I've found on a few AV forums people complaining of sparks when they hook the cables up to their expensive kit inside the house, it seems these cables do carry about 90 volts, although very little current. So, satisfied that it's safe although still not terribly keen to start fondling the end of the cable, my thoughts turn to how best to cap it off to stop the slightly disconcerting pyrotechnic display when it rains.
Any ideas? I could stick a bit of heatshrink tubing over the end and sticking out a bit, shrink it, fold the excess back over the cable end then put another bit of heatshrink on to seal that.
I did think of a resin joint kit as on the link below, but it seems a bit OTT (and I'm too mean to spend the £11 !
http://www.ebay.co.uk/itm/Resin-Und...al_Components_Supplies_ET&hash=item232aac7492
