Penners
- Suffolk, England
I've got an electrical problem in the house, that I just can't fathom out. If any electrical experts have any ideas, I'd be extremely grateful.
First some background: Our Belling 4-ring electric cooker (bought new 4 years ago, and in good nick) is powered by its own dedicated radial circuit. There's a 45A MCB in the consumer unit, supplying a 6mm^2 TWE cable that runs exclusively to the cooker. There's a double-pole cooker switch on the kitchen wall, with an integral plug socket that's almost never used.
The cable from the cooker switch runs down inside the wall and emerges at a 30A junction box on the wall behind the cooker, and the 6mm cooker cable is joined to it within that junction box.
The whole consumer unit is protected by a master RCD. All circuits are supplied through MCBs.
Now the problem: three times in the last couple of months, there's been a bang in the kitchen (from the area of the cooker), and all the power has gone off. On checking the consumer unit, I have found that the cooker MCB has tripped off and the master RCD has done the same.
On every occasion, none of the heating elements on the cooker has been switched on. The main cooker switch on the wall has been on, hence the cooker's clock has been running, but that's all. And once the power is restored, everything on the cooker works normally.
I know that some cookers have rather dodgy heating element controls, which makes it quite difficult to tell whether they are properly switched off or not. Ours isn't like that - it has very clear off positions on all functions.
I've double-checked all the supply cable connections inside the back of the cooker and in the junction box - they're all well made.
As I've said, when the incident occurs, there is an audible bang from the area of the cooker.
Has anyone got any ideas what's going on, please? It's got me totally foxed!
