Hello
I’m a soon to be period property owner, I’ll be completing on an 1866 mid-terrace house in Faversham on Tuesday. I’ve got a question about amorphous ribbon underfloor heating.
The house has got partial central heating and I’m thinking of putting electric underfloor heating into the living room (which has an open fire as its only heat source). It’s got a suspended timber floor over the cellar, with bare floorboards above and exposed beams and boards in the cellar.
So far Allbrite’s amorphous ribbon heating looks like a good idea:
http://www.allbriteuk.co.uk/ribbon-underfloor-heating.html
It’s laid over the subfloor on top of a layer of insulation and directly under the floor covering (in my case this will be a floating laminate floor). The heating elements run at about 28°C. I figure that as long as I make sure that there’s good ventilation to the floor from the cellar then the system would heat the room, draft proof the floor and protect the floorboards.
I’ve also seen carbon film UFH systems, they’re similar but they can’t be used under carpets or in wet areas, and although that’s not an issue in this case it would be nice to have the option to carpet the living room if we get sick of the laminate.
Has any here had any experience of Allbrite’s system? Also, can anyone spot any flaws in my reasoning or offer any suggestions?
Thanks in advance
Patrick
Thanks in advance
Patrick
