Hello,
I received the keys to my dream forever home 2 months ago, a detached Edwardian blonde sandstone. I'm currently living in a rented property until the renovation is complete, I set a 6-month timeframe but I highly underestimated what would be involved in this renovation and the time to find contractors who are willing to renovate this type of property. Everybody I speak to wants to plasterboard and gypsum skim everything. I'm not going to let that happen.
I'm now focused on completing four rooms so I can move in as costs are spiralling: Kitchen, Bathroom, Master Bedroom and Living Room.
The property required a re-wire, which is done, but the electricians have taken the path of least resistance to get wires in chasing everywhere, and I've resided myself to the fact I'm going to have to sort most of the plastering myself as I can't find anybody to do lime plaster that is in my budget, even those that are expensive have 8-12 month timescales. I have absolutely no plastering skills and only basic DIY skills, but needs must. I've read as much of this forum as I could and watched lime plastering videos on youtube.
I've stripped back all the wallpaper in the house, some with 6 layers of wallpaper and woodchip wallpaper everywhere. In some rooms the plaster work is ok, in others, some very bad DIY has ruined large areas of the lath and plaster. i.e. I pulled out a gas fire and fake wooden lintel from the living room and I'm left with a giant area of lath/plaster missing 2m x 0.5m. In the kitchen, on one internal wall, I am back to brick as the plaster crumbled when the cupboards and tiles came off.
My plan is to patch repair what I can and use Erfurt Variovlies Plus lining paper which somebody on this forum recommended, then paint in breathable paint.
To try to get started if anybody can help me with the following questions, it would be greatly appreciated:
Thanks in advance for any help.
- I'm was thinking of using wood wool board where I need to "patch" large areas in lath walls. Can you dot dab wood wool board directly to a brick wall? I need to keep the thickness aligned with the lath otherwise the 15mm board will be set too high. Can I just use finishing lime plaster over the wood wool board?
- Usually when close to a fireplace you would use fire-resistant plasterboard, should I keep wood wool board away from those areas? I want to reinstate an original Edwardian cast iron fireplace that will function. If so how do I plaster up to those areas where the lath is damaged?
- Can you "skim" with lime finishing plaster over the existing lime walls or is it best just to patch burst areas? If so how should I prepare the wall before skimming?
- For large areas to patch plaster do you recommend fibreglass mesh with lime plaster or is this a no-go?
- What do you do in areas where Artex was used? I'm worried about asbestos if I tried to remove it, normally you would gypsum skim over it, can I do the same with lime plaster?
- For filling the chased areas of walls, what is the best route to fill these as its deep into the brick behind?
