lizziecupcakes
- London
Hi, this is a quick question. In a Edwardian property I am considering buying to renovate, the walls need replastering. They are very old and lime plastering is crumbling. I'm happy to do the work.
Question: I plan to replaster back to the external wall, i.e. strip the walls back to brick. By current building control regulations, Do I need to add insulation to the walls now? Someone mentioned that even in period properties, insulation must be added if you are planning to replaster after stripping it back to brick.
Thank you.
Thank you.
