Kensby
- Hertfordshire
Hi, my first posting here so please go gently.....
I have an Edwardian 4-bed semi with a long-term damp problem in the front ground floor room. Belatedly, I have started to investigate this and as a first step removed a hedge which previous owners had planted directly under the windows. This revealed a small blocked air grille which I cleared. No sign of the expected damp-proof course though. Digging down in the narrow strip of soil between wall and paving however, I soon found it, about an inch below ground level! What I also found though, only two bricks further down, was the top of the footings, where the brickwork starts to step out. This seems very shallow, is it normal in a house of this age?
So, my question is, would it be structurally unwise to expose the whole length of the wall down to the top of the footings? If so, how can I maintain the DPC at a suitable height above ground? Indeed, is a DPC of this age likely to be actually doing anything anyway? How about a French drain right up against the wall? Or would it be better to lower the height of the whole front yard?
I have already arranged to have the rotten wall-plate (sole plate?) and joist-ends replaced but am anxious that the underlying damp problem which has caused this should be remedied first. Any advice would be very gratefully received.
Thanks.
Thanks.
