Hi, we're in the process of moving in and in my enthusiasm to 'get to know' the old house went straight for the 4-5 layers of wallpaper and paint. Now that it's all off I can better see what I'm dealing with.
Starting with the ceiling. I know it's wooden laths attached to the joists. They are covered in a half inch thick layer of greyish blue undercoat which I assume is lime/hair/sand, topped off with a thin layer of lime plaster of some kind.
The walls have the same setup, brick then the same gray undercoat and finally a thin layer of plaster.
Obviously the plaster has blow off in large patches, but at least 70% of it is still on the walls and ceiling quite solidly.
I'd like to know what the best approach would be to dealing with it. I intend to do the work myself and I have ordered the following from Conserv:
2 x Natural Goat Hair (500g), 1 x Non-Hydraulic Lime Plaster Base (25kg), 1 x Non-Hydraulic Lime Plaster Finish (25kg), 1 x Traditional Lime Wash (10 Litre),
Ideally I would like to patch the large areas that are missing the old plaster, prep the whole surface, limewash and either limewash colour or claypaint.
Should I do anything to the cracks in undercoat?
I do not wish to overboard up the ceiling or the walls. I want a fresh layer to paint over, for both walls and ceiling.
Thank you!
Thank you!
