victorianjob
After 5 long months our roof is almost complete and 80% of the repointing has been done so we are almost watertight. Prior to the work the house was empty for 9 years so was in a very bad damp/wet state. Not surprisingly, there was extensive dry rot and we lost entire floors in a couple of rooms. We are now keen to further reduce the moisture levels in the timber and masonry so we can start replacing and rebuilding.
What type of heating/drying method would be best employed? (I know space heaters create lots of vapour) We have a single dehumidifier that we are planning to use and maybe get a more heavy duty one. There is no central heating. Ideally I'd like to use a form of heating that is moveable from room to room. Does a dehumidifier work with drying the wood or will we just be extracting moisture from the air? We have some timbers that have moisture contents or 18-22% (in the danger zone for dry rot) and want to get them out of the danger zone asap.
We don't have any near neighbours so suggested to my Dad and husband that we use a wood burner and move it around the upstairs rooms, sticking the flue out of the window :shock: , to which they suggested I needed sectioning!
Thanks in advance, Cheryl
