Hello,
I am in the process of purchasing a grade2 granite built property circa 1830 which has an extensive dry-rot issue in the lounge and dining room areas. A couple of specialist companies have been out and their reports stated that all of the ground floor wood work will need to be removed including part of the staircase! They also recommend that the floor voids are concrete filled and tanked to prevent future outbreaks.
The dry-rot was caused by a leaking internal downpipe and poor floor ventilation due to carpet covering the vents. The property has been empty for some time.
While this work was being done I was thinking of removing the partition wall between the lounge and dining room to create a larger lounge area.
My question is what are my chances that the local authority will allow the floors to be repaired in this way i.e. concrete filled and the partition wall removed? There is a covenant in the home information pack dated 1987 stating that one of the doorways will be bricked up and a new wall erected and this work appears to have been done so the local authority was flexible then! Also the rear of the property has double glazing while the front has traditional sash windows. The double glazing is not mentioned under the covenants in the home information pack! Could the double glazing have been done without authority from the council and would I be liable if the council decided this was not in keeping with the building even though it was done in the past by previous owners?
What other measures can I take whilst the sale is progressing to safeguard my investment as I know nothing about listed property rules and regs!
Thanks in advance
J Keen
Thanks in advance
J Keen
