We are about to buy an older property where there is excessive moisture in the external walls (solid masonry). We are planning on stripping off the modern plaster and re-plastering in lime. I did wonder though, due to the solid walls, if building control might insist on us insulating the walls. We are planning on stripping back all ground floor rooms, externall walls to ceiling height. The house is not listed. I guess if we are obliged to add insulation then that will lead us to dry lining. Does anyone have any experience of this? I guess we need to ensure that ventilation is intruduced to stop rot behind the new walls. Interested in your thoughts/experiences. Thanks.
