gsport george
- Sheffield
Hi,
Been meaning to post this for a while.
I dont know if this was done in the past, but it seemed like a good solution to me.
The thinking is that it doesnt matter if the window is draughty when it is open, so the last half inch or so of the sashes' movement can deal with any draughts. This is a new sash, so was made with the central bars correctly sized to wedge inwards on the bottom sash and outwards on the top, but on an old window you could just add a thin strip of wood to one of these to create the correct spacing. Then the little block shown is added to the inside bottom of the parting bead and the outside top of the parting bead on each side.
When the window is closed the last half inch of movement jams the inside face of the lower sash against the staff bead and the outside face of the upper sash against the outer cheeks. To get a really good "seal" it obviously depends on the faces of the sashes being a good fit with the frame, but the staff bead can easily be adjusted and for the ten minutes this takes compared to routing things out etc, it is pretty good.
When repairing the frame and replacing the sill, I also added the small detail to the base of the outer faces to aid drainage (as that was where all my windows had started their rot by the looks...)
George
George
