The rain water goods on my property and that of my neighbours drain to a single downpipe which drains into a 'drain' at front of my property. This is about four foot below road level (we have steps down to our front door).
The existing drain whilst clear is very old (beautifully constructed brick circular drain approx 300mm in diameter). This goes under the steps which lead down to our front door and I suspect used to drain into the canal (now no longer in use and filled in) that ran down the side of our house.
I intend to get a CCTV survey of the drain and determine where it leads however I suspect the answer will be nowhere.
If we assume for the moment the drain doesn't go anywhere I have a singificant amount of water going into what is probably effectively a soakaway under our steps and only four foot from the front of the house. There is signs of movement in the ground above this area which leads me to believe this may be causing an issue.
If we also assume that I need to find an alternative location for this water to go I can think of only one solution - redirecting the output from the downpipe onto the pavement and ultimately onto the road. There is no location to have a proper soakaway (needing a min 5m distance between the house and soakaway).
Any suggestions for alternative solutions. I suspect building control maybe be a good start....
