As I've mentioned perviously I have an Edwardian stone walled property. There is the necassary gap between the internal lath and plaster and the outer stone walls but that is not my current concern. My concern is the gap between the ground floor ceiling and the floor above. This gap is partially filled with a suspended ash layer but has a void below the ash layer which extends right across the house and is open to the 'cavity' behind the lath and plaster. Thus any heat lost though the ground floor ceiling escapes into the 'cavity'. Worse still, if there is a wind outside there is a draft through that void.
I'm thinking it makes sense to try to block the void at the floor ends to reduce the drafts from the gap behind the lath and plaster. But am I right in thinking that minimising the air flow above the ceiling should not cause any damp issues since there should not be any damp in either the ceiling or floor above (unless my daughter floods the shower again ) and the rooms should be at similar temperatures.
Can anyone see any other issues with reducing that air flow?
Would expanding foam be an appropriate material to use or is there a better alternative, remembering that access is not easy and the gap is irregular?
Any thought would be most welcome.
Drew
Drew
