H housewinnie Member Messages 150 Location somerset Apr 12, 2023 #1 Up by chimney flashing have a broken Double Roman tile, any tips on removing, are the nailed or just hooked in place? Cheers all in advance
A a twig Moderator Messages 2,056 Apr 12, 2023 #2 Depends on the installer - if you are lucky they may just be hooked over, on our roof the installers had only nailed every 3rd tile. Otherwise could be one central nail or two 1/3rd in from each edge
88v8 Member Messages 3,131 Location Glorious Gloucs Apr 16, 2023 #3 If it is nailed, a slate ripper might help, depending whether it will insert below the curve of the tile.
