Feltwell
- Shropshire, England
I've managed to pick up a batch of 8 roof windows, very similar to the "Replica Rooflight" - i.e. copies of the original cast iron Victorian windows. These particular ones were made a few years ago as a one-off - someone doing a conversion on a old dairy building had links with a foundry and had them made up. They appear to be in cast aluminium, but despite that are still extremely heavy!
The question is - they aren't fantastically well-designed, the glazing units sit in a rebate and are held in place with (lots of) mastic. Internally they look fine, there is a smear of clear silicone between the glazing units and the frame that can hardly be seen. Externally though is a different matter, there is a very heavy fillet of a black silicon-type sealant holding them in, in much the same way as you would use linseed putty on a single-glazed wooden window.
This black sealant has not been very well applied and is badly discoloured and in places peeling away, after 8 years exposure.
Rather than just cutting out the sealant to replace it with fresh, I was thinking of gluing in a hardwood fillet and then painting it with linseed paint, overlapping onto the glass to help hide the double glazing unit seal (having first put some shellac on to keep the linseed away from the DG seals). Has anyone any better ideas, or know of a black sealant which will not discolour? I had thought about using ordinary linseed putty and painting it, but am concerned about the effect on the DG seals if the linseed reaches them.
Also, when scraping off a small area of sealant, a foil type tape that surrounds the glazing unit comes away with it. What does this do, and do I need to worry about replacing it? (Biff !)
I wouldn't put these on a house, there is no thermal lining of any kind and I reckon they'd suffer from condensation, but in my case they are for an unheated outbuilding so it's not a problem. I could replace the DG units with single glazing but it seems a waste as there's nothing wrong with them, plus the depth of the window is designed to take a DG unit.
