JoceAndChris
- Lincolnshire
http://www.omnipole.com/omnipole_trailer_systems.htm
I haven't used that particular company, but for three years they've been pressure washed monthly with a very similar system of a van filled with chemically treated water and a hose blasting this water - no rubbing or squeegee required as the water is treated to dry smear-free. It has cost me just £15 a month for the 17 exterior windows -but look:
Admittedly, I ought to have gouged this rot out sooner and done something about it, but there's no doubt in my mind now that this window cleaning system is not suitable for antique windows, and it probably isn't great for the house either where the water flows down. I've just phoned Holkams and their sales lady said I should not use this type of cleaning on linseed paint. The windows are still in their old, cracked exterior gloss but the plan is linseed paint ASAP.
Now for the difficult task of telling this poor window cleaner he's lost a job.
Interestingly, this comes from a very good summary of do's and don'ts with older buildings:
"Chemical cleaning agents such as acids and alkalis react with stone and brick as well as dirt layers, causing damage, and all can leave harmful residues behind.Water even under low pressure soaks masonry and can cause surface staining and efflorescence (salt crystallisation), and in the worst cases may lead to the decay of masonry."
http://www.buildingconservation.com/articles/ten/tenways.htm
I'm now wondering what to do with the rotted out sections. My dad is urging me to paint on "Wet Rot Wood Hardener", and when he has a chance (which will be October) he will help me splice and repair them. I wonder if "Wet Rot Wood Hardener" is really a good idea, and if it combines well with linseed oil paint. Any thoughts?
