Do not underestimate just how much air is needed for blasting. Used to work for a fabrication shop that did a fair bit of blasting. Needed a diesel powered Hydrovane to supply enough air. I purchased a small spot blasting gun a couple of years back, swayed by the blurb on the side of the box that it only needed 5-6cfm. It needs a lot more to be effective.... Oh, and it eats blast media like there is no tomorrow.I’m wondering if anyone has attempted soda blasting their beams themselves?
I got a quote for our beams and it was over 9k
So even buying a compressor and the other stuff needed would be way cheaper!! Anyone done similar themselves ?!
HiHi folks,
Thanks for any insights or advice!
I have only ever used oxo as a mild bleach, it works especially well on iron stains, not sure it would do much as a stripper. It's best used boiling hot, so I guess being a boiling acid (about as powerful as citric or acetic acid) then it might have some oompf when washing off chalk paints and limewash. Again, being a boiling acid it might also remove some grime and grease but that's not it's primary use, which is a wood and metal bleach. ( kills algae and mould too and cleans patinated brass etc) Poutice strippers are designed for very thick films, you might find for thin layers of grease and dirt that a DCM solvent stripper works best. Friable areas are really a suck it and see affair. Structurally they aren't doing anything important, it's more aesthetics. You just try and be careful as you can, but if you fiddle around with them, some parts will crumble, that's just what happens.Just jumping into this as we have some 'black' beams (all in one room) and some that are just 'dirty' from years of pipe smoke and 100's of years of grime. Will probably try klingstrip first.
What about oxalic acid crystals and water? Does that just remove grime or all it remove any paint?
And on the subject of badly worm damaged and friable sections of beams (talking roof purlins principally) what would you do to them? Should I try and remove the friable bits? Or leave well alone? I can attach some pics later.
Assuming your quote was from someone accredited by either Stonehealth or Restorative Techniques, then you certainly couldn’t buy everything you need for way less. New kit will be £8-10k for the blasting unit alone (TORQ or VorTech), plus rental of a serious compressor and diesel to run it, £500/ton for the media aggregate. Although, you won’t know which media you need to remove just enough to minimise manage, without trialling media and pressure and distance to achieve the right effect with minimal dwell time.So even buying a compressor and the other stuff needed would be way cheaper!! Anyone done similar themselves ?
