CHRIS
- ESSEX MATE!
I had been away for the weekend in the Peak District doing a spot of walking only to find when returning home that my water pressure was low, had a check around outside - no leaks etc, phone 3 valleys no work going on. Later on decided to go to the cellar (dont know why I did not look before) DISASTER !!!! 2FT OF WATER AND TONNES OF GEAR FLOATING AROUND. Same next door his cellar was flooded.
Took water co a few hrs to come out to try and stop water flow to both houses and would you belive it - the valve is jammed open so we are still filling up with water even though our stop cocks are off, must be a leak underground. 3 valleys say they will fix sometime today.
any ideas how to dry out flint/brick cellar with lime washed finish (nasty conc floor installed in 1966) without doing too much damage?
