FamilyWiggs
- Flintshire, N Wales.
Been a while since I posted... and I've dropped down to 9th most prolific poster on the site... :shock:
A recap. We live in a 1650s-ish Welsh stone farmhouse, which had had the usual mistreatment which we are slowly rectifying. Currently in year 12 of a 3 year project. SWMBO still doesn't understand the value of patience, planning, kitkats, the need for new tools and the fact that any job worth finishing isn't.
Current problem... one end of the house is buried in the mountain we live on upto first floor level. It wasn't built this way but some time between 15 and 50? years ago the cattleyard was concreted over (hopefully leaving the cobbles in place) and this meant filling in around one end of the house. It happens to be the dining room. If you imagine that the house is a cross shape with one long axis and a landslip has engulfed one end and that the "sides" of the slip are now concrete steps between the two levels that wrap around the end of the house by around a dozen feet, you'll get the idea. It's a bit more complex on one side where the "slip" comes as far as the central cross, but essentially the same problem.
We now have penetrating damp starting to cause a problem, 8 years after we removed the polythene tanking and replastered internally in lime. It seemed to be fine for the first 5 or 6 years and we were hopeful the lime plaster would self-regulate the moisture moving through, but damp has appeared in the past couple of years and the plaster is blowing in places. Maybe it is wetter recently and more water is moving though the mountain and under the house. It is starting to corrode electrical backboxes and cause the occasional RCD issue.
So clearly time to sort properly - by removing tons and tons and tons of earth and creating a retaining wall around the house so the walls can dry out and the ground level reduced to where it should be. We might even be able to reinstate the two windows in the dining room. The yard needs to remain usable (it is the drive). The difference in height is about 8 feet and the yard is 20 feet wide with 2-story stone outbuildings running parallel with the end of the house on the other side of the yard. 20 feet would give me enough width to have a walkway round the house, an 8-foot vertical retaining wall and enough mass to support the necessary 45 degrees upto the base of the outbuilding... I think.
All in all, a structural conundrum as I wouldn't like the outbuildings to collapse (again! - but that was another story....detailed on here somewhere).
Anyone got any tips on how to go about this? I'm assuming a structural engineer's advice would be sensible rather than just hire a JCB and start digging. I'm thinking of excavating one set of steps and digging out by hand up to the end of the building on one side, just to assess the state of the buried wall/stonework - sound sensible?
If I excavate slowly and build a retaining wall (in concrete blocks?) as I move round the house, is that one way of doing it. Or am I better to excavate a 45 degree slope down to the base of the house wall, build the retaining wall and then back fill the slope level again with the yard floor? If I do the latter I could put some draining pipes into the wall and backfill but it will mean destroying any possible cobbles under the concrete yard. How strong a retaining wall will I need for 8 feet tall?
Long post, thanks for getting this far.... anyone had similar problems or got structural expertise? It's a bit more than the usual "dig a French drain" issue often posted on here!
