Nigel Watts
- London N7
Following some subsidence caused by an over-thirsty Eucalyptus tree a number of cracks opened up in our rear two storey extension (below).
The tree was got rid off, the cracks then shrank somewhat and after they had stabilised they were filled.
After the rain of the recent days the upper room has a strong smell of damp plaster. Above it is a flat roof with parapet walls. There is no damp discolouration anywhere, but the side of the room most effected by the cracking has built-in cupboards so cant be fully inspected. Modern plasters and finishes were used. Most of the exterior wall is 9 inch brickwork with no cavity, faced on the inside with expanded polystyrene-backed plasterboard.
I would like to diagnose and fix the problem. Any ideas? Should I buy a damp meter?
