Nigel Watts
- London N7
There is a nasty damp stain on my drawing room ceiling immediately below the position of the drain of the shower in the bathroom on the floor above, which I have now banned anyone from using.
The bathroom floor has plywood screwed down over the original floorboards which in turn is covered in lino. There is no waterproof membrane as I understand is often used these days in wet rooms. The joint between the floor and the shower tray is sealed with silicone mastic. The shower tray sits directly on the original floorboards and the U bend extends into the void between the floor and the ceiling of the drawing room.
The source of the leak could be a plumbing defect or it could be water which has overflowed the shower tray and penetrated the seal. The shower outflow often gets a bit blocked, probably because there is insufficient fall between the U bend and where the pipe exists through the external wall, but I suspect the former.
Should I:
a. cut a hole in the drawing room ceiling and try to diagnose/mend the problem from below (the ceiling is original lath and plaster but not in great shape). I'm not too keen on this as more might come down than I anticipate.
b. cut a hole in the lino/plywood to access the U bend and then try to make good by patching in a new piece.
c. something else?
A solution to this problem will please my wife no end.
Should I:
c. something else?
