malcolm
& Clementine the cat
- Bedfordshire
I've been reading up on the internet (perhaps not the best place) and in books (again the ones I looked at were not the right place) and am becoming more and more confused.
It seems that if you add 60mm of nice breathable wood fibre board insulation internally to your lime mortared brick wall the dew point will fall within the insulation and that is considered bad. Mould will grow and everything will get soggy and rot (even if done properly with lots of lime and no air gaps).
But looking at dew point tables if you don't add any insulation at all the dew point would still be within the brick wall. That doesn't seem to have caused any problems for walls that have been here for the last 400 years (though perhaps toasty warm inside for only the last 40 years).
Current thinking proposes impermeable insulation or vapour barriers but I'm not convinced as the temperature difference is the other way around in the summer and a vapour barrier would cause a problem. I haven't found any hand calculations to help which makes it seem like a witch's brew.
The most sensible opinion is the one I have found on this forum - if the room is not damp then breathable insulation is probably OK so long as air leakage to behind the insulation is minimised. A vapour barrier is not required - the wall will settle down and do it's own thing with excess moisture able to escape. That makes sense to me based on what I have seen here - the only part of timber frame I had that remained beetle free behind the nasty external concrete render (since removed) was a perfectly preserved wall plate which was able to send moisture a foot back into the internal wall. Wood fibre insulation is a bit like wood so surely it would do the same thing? I think current thinking in insulation underestimates breathability whatever the temperature gradient.
I'm going on a bit, but I'm going to have to take the plunge this year and fit all the insulation so I can make building regs go away. Does the last paragraph sound sensible?
