Hi there any ideas greatly received pls
Bought a cottage / had no idea about Cobb /renders/ nor did the level 3 survey / surveyor apparently but now I understand the situation and how we need to have the render taken off and lime plaster inside and outside / breathable paints etc. one day …..
However today s fresh hell was : I looked under the carpet in the lounge to see if it was damp as the edges of the walls were.
Hey presto ! Damp chip board throughout the lounge /diner. Have been told to take the carpet/underlay out - let the areas dry.
Moving forward how do u fix the problem? There is a blue plastic membrane under the chip board ?!!
Do you put limecement down? Under floor heating? Is this particularly costly? Any advise greatly received
Many thanks
Many thanks
