DaveBrigg
- North Lincs
Work in garden had to be put on hold last weekend because it was getting too muddy. Instead, I prised the cement panels off of the lime plaster on our staircase wall and found - mud. Mud and straw daubed on a panel of reeds, the reeds being held in place by a vertical lath on each stud.
As you can see, there is a big patch which need to be replastered, and some areas that first need repairing. However, the surviving reeds are extremely fragile and not likely to withstand a generous coating of muck. I can get replacements locally, but fitting them would involve cutting out a section of the original materials far bigger than the area damaged.
Another section of this wall has been repaired historically by having laths jammed in across the gap, which were then plastered over.
A local horse livery yard was happy to provide several bags of hair, and I have some willow staves which have been drying for six months, the perfect size to be split for laths. Is willow suitable for use this way, or will I have to source some ash?
I would also be interested to hear from anyone who has done something like this themselves. I've read the SPAB advice, but could do with some clearer guidance on what to include in the daub mix.
