Nigel Watts
- London N7
Just started preparing for decorating in my first floor bathroom (a former bedroom).
The cornice is a simple cove, large, with quite a broad flat continuation on the ceiling and wall. I have been peeling the paint off it in sheets revealing a solid pink plaster construction, which must have been run in-situ, and originally decorated in distemper or white wash, hence the peeling paint, and patched up here and here in very hard pollfilla which is impossible to remove without damaging the softer plaster. Ceiling is plasterboard over original lath and must have been repaired before the cornice was put up.
Plasterboard and modern plaster, but run in-situ and decorated with distemper or whitewash. 1960s perhaps?
Needless to say the hard gypsum of the cornice and one of the replastered stud walls has not married well with the original lime nor coped well with the movememt of the house. The cornice is badly cracked in a number of places and the gypsum has weakened the lime in the corner of the room where walls made of these different materials join and where there has been some movement; the gypsum seems to have pulled the lime from the wall as it moved (if it had all been lime it would still have cracked but probably remained adhered to the walls).
