I was asked to post some photos of the dampproofing of the basement in my georgian town house while in progress. The basement had clearly suffered persistent damp problems over the years with a tide mark of damp to the touch plaster up to c.4 feet. Prior attempts to solve the problem included patches of cement rendering, chemical injections in the walls and a bitumen floor coating. My neighbours have both covered the walls and floors with waterproof cement render to the ceiling, so any water in the parties walls would likely to be coming out on my side. We decided that rather than fight the damp with more of the same that we would cover the floor and walls with a cavity drain membrane (a studded plastic sheet) that covers the walls and floor, but allows any water to come through the wall and either evaporate or flow down into floor drains and then into a sump. This means that the water isn't trapped in the bricks and so the wall structure isn't damaged. It is also easily removeable so if a subsequent owner wishes to remove it they can do so.
Having decided on the approach, we needed to dig out the 1950s concrete floor which had no DPM in it or any insulation, and rebuild the floor with the following structure bottom up: hardcore, 50mm insulation, concrete slab, thin coat of leveling screed, 50mm insulation, cavity drain membrane, underfloor heading pipes, screed, stone.
The following pictures show:
1) the original basement prior to an interior wall being knocked through,
2) the membrane being attached to the walls in the under pavement vault. The floor here is the screed put down to level it to ensure that any water will flow in the right direction. The membrane is held up by plastic pegs that are knocked into holes drilled into the walls, with a mastic around the head to seal the hole.
3) the membrane up, the floor drains in place around the perimeter and the floor insulation being laid. Note the rodding point on the right - this enables the drains to be flushed with water from a hose to clear any sediment that builds up.
