I own a mid to late 18th Century brick terraced cottage which has been largely unoccupied and unheated, although furnished, for most of the last decade, and has never had central heating fitted.
There is damp in the sitting room, and particularly around the chimney breast, to a height of about 12" from the floor - the builders who were due to install floors and heating suggested a damp survey before proceeding. It's currently fairly bad (paint has peeled, slight crumbling), but isn't worsening.
I had the usual free survey, which confirmed only that there was damp in the walls (no surprise). The recommendation was, as expected, a chemical DPC throughout (the front wall of the property at least has at some point been treated previously, although it obviously isn't working).
The roof, gutters and chimney are all sound.
I don't want to waste money on a chemical DPC which may not work - how likely is it that with some heat and ventilation it may dry out of its own accord? What else could I try?
Thanks in advance.
Thanks in advance.
