Carina
Hi all!
We have recently bought a ground floor flat in a converted chapel (built mid 19th century).The building is the typical sort of stone chapels you find in Somerset with thick stone walls. It was converted into housing 10 years ago, and is in very good shape in general. However, one outside wall in the guest room shows some sign of damp, with paint pealing from a wall in a few places. The exterior of the wall in question never really receives any sunlight and the inside of the wall is very cold to the touch, there is also a quite substantial amount of condensation on that particular wall.
We've been told not to worry too much as the building is generally very well preserved, the outside walls don't seem to need repointing, and the problem is limited to only the one spot in the house. Of course, we are still a bit worried
. This is our first house and we don't want to ignore a potentially serious problem. However, we've only just spent all our savings in order to buy the house and we can't really afford to spend a fortune on damp removal specialists at the moment.
If anyone can provide any sort of advise it would be greatly appreciated. Obviously we're considering getting a specialist in to check it, but we've been warned that they will always advise that work needs doing, even when it actually doesn't..
Kind Regards,
Carina
Kind Regards,
Carina
