Hello.
Having read through some old posts, I realise what a minefield this subject is, but I hope I can get some useful advice here.
We live in a Victorian brick-built end-terrace house. When we moved in just over a year ago, the survey showed up some areas of damp in the dining room chimney breast, but the advice was 'it's just one of those things you have to live with in a house of this age' (you can't actually see any damp patches).
We have now got a large (and spreading) area of damp (visibly obvious- and very wet to the touch) around the chimney breast and exterior wall in the loft conversion which is our main bedroom.
Today we had a survey by a local company who tested all our walls with a damp meter which appeared to show very high levels in all walls. He said it was penetrating damp and recommended a chemical treatment to the entire exterior brickwork (which you can see is quite crumbly and porous in places) which apparently stops water penetrating while still allowing the wall to breathe.
Is this a good idea? Will it cure our very damp bedroom? Or is that more likely to be condensation, or a problem with the roof? There are no other damp stains in evidence anywhere else in the house.
Sorry this is a bit long-winded, I just feel very confused by all the advice I have read.
Thank you.
Eleanor
Thank you.
Eleanor
