I've now replastered the dining room. However I appear to have a damp problem where there 'appeared' to be none before.
Original plaster is a daub base, with well haired lime skim onto stonework (600-900mm stone walls). It had been emulsioned/wallpapered/emulsioned a few times so this was removed as carefully as possible. This left about 60% intact original plaster but not a sufficiently good surface (after all the scraping) to be left as the finished surface.
I then went about repairing with lime scratch and devil coats up to the level of the existing plaster before skimming the whole surface to give a good finish.
I now have what appear to be damp areas where the old daub/lime skim is behind the new finish coat. These just don't appear to be drying out - all the areas where the plaster was fully replaced have dried out very well. If you stand back from the wall you can clearly see where the original plaster remains.
My question is therefore 'is daub less breathable than lime'? and have I effectively trapped the moisture now in the daub by skimming over the top? (although I can't see how). I must admit this is the only external wall that is left to repoint (and badly in need of it!) but I can't see why the two backgrounds are so different in their breathability. My only thought was that the daub probably has a lot of clay in it which may hold the moisture content higher.
Any thoughts/suggestions as to best approach to resolving?. Since it's only two walls the worst case scenario would be to start again but I'd rather not have to.
