jca
- Twyford, Berkshire
Hi Folks,
I have a damp spot the middle of a ground floor party wall of our 1890's terrace. The damp patch has a discrete outline, and starts at skirting board level rising to about 30 cm up the wall. Having done a little reading round on damp, I suspect this is not due to the most common causes of blocked drains or plumbing (there are none around this area of the property) or leakage (it's in the middle of the wall, a good 3 feet from the exterior of the property, with no sign of leakage around the roof, or damp in the room above). When we moved in last year, I thought there was a trace of a damp spot in this area, but found the air bricks at the front of the property were obstructed, so cleared them and hoped it would go away. I think in this time it has actually got worse, however. This house does seem to have been subject to minor movement, which I suspect may have fractured what I assume to be a slate DPC. Does this sound like the most likely cause, and if so, is it necessary to have a chemical DPC treatment to the entire house, or can just the affected area be treated, given there are no problems elsewhere? I'm really trying to get an idea of the probable cause so that when I get someone in to look at it, I have a vague idea if they are trying to pull a fast-one or not.
On that topic, I'm trying to find someone to take a look at it,and understand that most damp treatment companies are affiliated with particular treatments they will try to sell you regardless of their suitability. I would therefore prefer to find an independant specialist who will give sensible advice on what realistically needs doing.
The question is, how can I go about identifying independent specialists from the yellow pages, since in most cases the ads don't seem to mention affiliations with treatment firms etc? Am I best just choosing someone who is a member of the BWPDA and hoping for the best? Take it as read that I don't know anyone in the area who has had damp work done, so can't go by word of mouth!
Thanks,
James
Thanks,
James
