The original part of my house was built sometime before 1742 and has random stone, rubble filled walls and naturally, no proper DPC. There is no question about the presence of damp (the evidence is all too clear), but the issue is the correct remedial treatment. Everything I have read (particularly on this forum) tells me that modern chemical solutions are unlikely to work.
My research also tells me that the place to start is identification/elimination of sources of damp. I certainly have a number of these, some of which may have solutions and some of which probably will not. This may mean ‘living with’ the remaining problems.
While the property is detached, I only own the land on one side. One of the other walls is directly adjacent to a sloping tarmac lane which is undrained. On this wall, interior floor levels are just above the outside level at the closest point. The other two sides both have guttering downpipes draining from my roof directly onto the adjacent land (earth) belonging to my neighbour - there are no drains, but internal floor levels are well above outside earth levels. There IS mains drainage on the one side that I own.
Probably of most significance, is that the house stands on a sloping site, under which water courses are known to run. This probably means that my rubble-filled cellars are also filled with water! The floors are (now) solid, which presumably, forces any moisture beneath to the walls.
Actually documenting these issues is frightening in itself, particularly as it may not be possible to eradicate all of the sources of damp. Does anyone have any views and, in particular, can anyone recommend a suitable expert. I have already been disappointed by previous ‘experts’ and I much prefer to pay just once (more) for the definitive solution(s). Incidentally, I live near Chesterfield.
