A
Anonymous
Guest
Hello there, this is my first posting on the forum so please be gentle..... : )
I have a 1901 brick built mid-terrace house, in a high ground water level area. The house has been injected with a chemical DPC two years ago (specialised no longer in business). I now know, that they’re not very effective, especially where the walls are damp (kind of defeats the object really).
As the damp has not stopped, I am now considering putting in a physical DPC, as a first step. However there are a couple of things that are proving difficult to find out about.
Are the walls solid or cavity? The bricks are 4 x 9 inch & as the courses show the ends of the bricks as well as the face; does this mean there is a 1 inch cavity? Or is this not classed as a cavity in its’ true sense?
In which case do I have to treat each side as a separate skin & put two separate DPC’s in or as one wide DPC that covers the full 9 inches?
Also is there any guidance or wisdom on the pros & cons of slate v modern DPC?
I would also like to install air vents high up in an under stairs cupboards to remove any moist damp air. So when installing the vent, again do I have to fit 2 separate air vents, 1 in each skin (at the same position of course) or 1 that is 9 inches deep?
As only part of the house has wooden floors & the rest is concrete (inside & out) is there a way I can make it easier for the damp below the DPC to evaporate?
I would appreciate any advice you can give.
