A
Anonymous
Guest
We own a ground floor purpose built flat in a 2 storey Victorian house built sometime between 1890 and 1901. We live in London near the Thames in Putney. The rear of the house was extended, and although the council have no record of plans, we have been told that the type of construction material indicates that the extension was done shortly after the house was built. The extension has a concrete floor and we have found that after heavy rains the floor becomes damp causing the wooden flooring that has been laid over it to buckle and rise.
We contacted a number of damp companies all of whom observed the following:
- it is not clear whether any damp proof layer was installed under the concrete floor of the extension;
- the patio outside is too high and is therefore breaching the damp coursing in the walls;
- there is little surface damp on the interior of the walls;
- there is damp within the walls, but this is not unusual because they are not cavity walls.
These companies suggested digging a french drain about 1 foot from the wall, and covering the concrete floor with a membrane before putting carpet/wooden flooring down.
However, we have had one specialist who told us that we don't have rising damp but suggested that the house is built over an aquifer or other body of water, that the water levels are rising and that the walls throughout the flat, internal and external, are saturated. He has told us that the plastering throughout the flat is "tank grade" and that the extension would have had damp proofing installed when it was built. He has suggested:
- having tests done to determine the "moisture profile" and level of salts in the walls (i.e. drilling small holes to the core of the brickwork);
- that if there is a problem the walls could be injected with a solution to stop absorption of water and to allow the walls to dry out.
Please could you help with the following:
1. We don't know who to believe - none of our neighbours have had this problem (it is a terraced house), and it was not picked up in the survey when we bought the property. Also, the problem only seems to manifest after heavy rains, and only one person out of the 6 that visited us have identified this as a problem. Can you recommend someone who can give us a second opinion?
2. If the walls are saturated, is the injection method the best remedy, and how much is it likely to cost?
3. If the walls are injected with this solution, what happens to the brick work below the level of the new dpc? Presumably they will remain waterlogged and therefore will become badly damaged. Are we at risk of the foundations being weakened?
Many thanks
Duncan
Many thanks
Duncan
