Janet BG
- Leicestershire
When we moved into our farmhouse (which is three cottages joined together to form a large farmhouse), we discovered old quarry tiles under the carpet in the lounge, the carpet had been in place for many many years! Unfortunately, the underlay had been glued firmly across the entire floor. After spending days trying to remove the glue, we realised it was a losing battle and decided to install a wooden floor instead. That floor has been in place for around three years.
Now that we're renovating the room, we’ve removed the wooden floor and noticed a strong smell of damp, The house has previously been treated for raising damp in the room.
Interestingly, the areas where we previously removed the glue from the quarry tiles were wet, whereas the tiles still covered in glue seemed fine. However, the skirting boards around the entire room showed signs of dampness. It seems the glue might have been acting as a barrier, preventing the damp from escaping.
I knew little about quarry tiles before today (Google has been my best friend!), but I now have a few questions I’d love some advice on:
- Now that we’ve managed to remove a large amount of the glue (around 50% of the room), we’re seeing significant efflorescence—so much so that sweeping leaves a noticeable pile of salts. Will this slow down over time? The tiles are in great condition once the glue is removed, so we’ve decided to keep them. Removing the tiles and replacing the floor with a concrete base feels like the only alternative, but we’d prefer to avoid that if possible.
- What's your thoughts on sealing them, is there such a thing as a breathable sealer?
- Could the rising damp in this room have been caused by the long-term presence of carpet, which may have trapped moisture with no way to escape?
