The cottage we are buying is a c. C16th timber-framed building on 4 floors, the lowest being a cellar that runs the complete length and width of the oldest part of the house. House sits on Wealden Clay.
The whole cellar is lined in dressed stone (disagreement between CO who says cellar is original and surveyor who says Victorian addition) and has a big damp problem.
This isn't helped by the cement pointing to the ashlar - the surfaces of a couple of the stones are starting to spall.
The surveyor says that an injected damp-proof treatment was carried out to the front and right-side party-wall elevations of the property in 2003 (and modern plaster applied). Does this mean it was applied to the first floor, or that it was applied down in the cellar?
Pretty much all the ventilation to the cellar has been blocked - either with bricks, or vast amounts of vegetation on the left gable wall at ground level choking the vents. Fortunately the ceiling consists of the floorboards of the main rooms above and nothing else. .
About a quarter of the cellar is about 7ft high with a tile floor (modern) with no grout and the rest has a solid concrete floor and is only about 5ft high at lowest point. There is a radiator in this part and it's much less damp. Where the tiled floor is, a ledge has been left all round the edge that is one tile high and one tile wide.
Ideally, we would like to take the whole of the cellar floor down to the 7ft high mark, re-point in lime, lay an appropriate floor (limecrete?) and get some serious ventilation into the place. Then we'd like to use it as a living-space (within the limitations of any under-ground room).
Before we do anything, we will have the appropriate people in to check that the house won't collapse! The LBO has already said that he doesn't have any objections to doing things in there.
Does anyone know what the reason would be for shoving up to 2ft of concrete over 3/4 of a floor? Is it dangerous to remove this?
Will try and find some photos.
