Hi, thoughts on this please ?
We have an Edwardian house (1908), with an open fire place which hasn't been used in over 15 years. The walls on either side of the fireplace are damp from the floor up to about a meter high, which we assume is where the connecting chimney pots were filled in with cement at some point and therefore allowing no air flow.
When we discovered this we obviously had the chimney stack repointed (lime Mortar), broken bricks replaced, removed all the old cracked flaunching and had new flaunching and new pots with new (airflow) caps fitted. The chimney was swept and cleaned. This was one year ago.
Internally, the fire place still has damp either side (we are assuming this will take an age to dry out properly, and perhaps we should start using the fire to support the drying process ?), but the adjacent walls also have large damp patches, also about a meter high in a square shape with hygroscopic salts appearing through the paint.
Can the damp from the chimney walls spread right across to adjacent walls ? or is the damp on the adjacent walls due to another problem ?
We are thinking about having the plaster removed internally in case it has been patched up with the wrong type (the rest of the internal walls are Lath & Plaster), if the wrong plaster has been used could this be causing external damp to soak in and appear on the inside ? does Lath & plaster stop this happening ? or.....
are we completely barking up the wrong tree and it is fireplace damp spreading ?
The entire wall with the chimney stack and damp problems is an external wall facing onto a large, wide open driveway.
Any thoughts much appreciated. x
