Tk242
- Gloucestershire
Hi all
I'm new to the forum & would appreciate any advice please. I have an old cottage (circa. 1860) brick construction with render applied at some point when an extension was added to the rear, lots of external cracks so ample opportunity for water ingress & its been applied with an awful Sandtex paint approx. 4-5 years ago (according to the neighbour) and it's peeling away on the side that takes the hit from the harshest weather. I had worried it may be a concrete render (still may be in parts) but after carrying out a vinegar test found we have lime, possibly a lime mix though I'm not an expert and would be interested to get it tested properly.
The issue I have is damp in the lounge, the internal walls were covered with an awful plastic paint which I've removed & didn't think we had too much of an issue until I applied a clay paint. Most of the walls dried aside from two areas, one I think is being caused by an issue with the window (need to explore that further) but the other is the external wall that's taking the hit from the harsh weather and has the paint peeling off externally. The ground on the exterior wall is also higher, suspect it has been for many years, nothing I can do about that as it's the neighbours drive & mains drains located there (need to check there's no leaks). The floor is concrete, not ideal but I can't take it up right now it's too much work when you live in the house with kids & my budget doesn't permit. I have however removed the awful thick Bitumen layer that was covering it. Ideally I'd remove the gypsum plaster & apply lime but I'm not in a position to do that at the moment. My question is regarding removal of the exterior paint, I've heard suggestions of the DOFF system but think this may be fairly costly (going to get some quotes) is there anything I can do myself to remove this without damaging the render?
The work on this house is relentless and not at all what I anticipated, none of it came up on the survey and everything has appeared when we've done work & removed wallpaper etc & found issues lurking. We are fairly handy DIYers though, have fitted new bathroom, removed non load bearing stud walls etc. so happy to do whatever we can.
Thanks in advance
Thanks in advance
