Hi everyone,
I have some damp issues (though not huge still annoying and I see paint bubbling up in some areas) in my ground floor Victorian flat (I think - built in early 1900s). When I had the building survey done, it highlighted the ground level at the back of the house being too high. I have a patio made up of bricks on one side and concrete blocks on the other side of the building.
Recently I decided to get my garden done and at the same time do something about the damp issues. I've had a few quotes from landscape gardeners for following options:
1. Leave the current patio but dig a trench around the house (remove a row of bricks from patio to do this) and install a french drain
2. Remove the current patio, dig out further and build a new patio with sandstone plus a french drain around the house
Option 1 costs about 2K and option 2 costs about 5.5K (both options include clearing the garden, laying turf and creating flower beds).
Obviously option 2 will look much nicer and it will add more value to the house but having done a full refurbishment, I am still under a bit of financial pressure so it's not an easy decision.
However if I go for just a french drain (option 1), I don't want to later find out, it hasn't solved the problem.
I know there's a lot of people here with experience/knowledge in damp problems and how to prevent it so would love to hear your opinion on what would work in my situation.
Will I be able to get away from having just a french drain (but higher ground level)?
If I go for reduced ground level and new patio, do I still need a french drain? Could I get away from not having a french drain? I wonder not having to install a french drain will save much money?
Thanks in advance for any input.
PS: I can't see the DPC level on the building. Either the ground level is above DPC or there was no DPC installed. I can see that the floor inside is either level with ground level outside or slightly lower.
