Jill
- North Lincolnshire
An interior wall in our stone cottage for some reason was never damp proofed when it was renovated 20 years ago. The wall in question is 22" thick. The wall clearly has some kind of damp problem as the lower third of the wall paper was a different colour to the top, (made more obvious with 20 years of Pauls nicotine on it).
From what we have read from various sources we believe that the only way of remedying this problem is to strip the wallpaper (already done) paint layer, plaster and cement/sand render to expose the stone wall? Paul would like to retain the stone wall as a feature but this will depend upon the stone. Any render/pointing should then be done with some kind of lime mortar to allow the wall to breath? I don't know what is between the stones but the house was built circa 1700 if not before.
Earlier in the year I did a test square (behind the sofa) so we could discover what was going on inside the wall, the cement/sand render seems dry and it was at the time of chiselling, and the stone was dry. It is just the plaster that seems to be the problem. Is this right or is the cement/sand the problem as well? This is about 2" thick. I spoke with Pauls brother who put the cement/sand render on originally and he said this was the correct mix as it was thought that the wall had been injected.
I know that getting rid of the render is going to be hard work but if this will stop the problem being so visible surely it will be worth it?
We also have a few damp patches on the outer walls in the same room where we believe the damp proofing stuff which was injected hasn't gone into all of the crevices. Any suggestions on what we could do with this to stop it showing on any wall finish that we decide to put on in future, it is currently wall papered but we are thinking of doing something else but what we haven't decided yet.
