I have a late-C18 (I think) terraced cottage, of solid single-brick construction, solid floor downstairs and a tiled roof with a very small roof void. It has been let for some years after a fairly involved renovation - the current tenants are not ventilating the property adequately nor keeping the house consistently warm, and a result, it’s fairly humid and black mould has appeared in the bedroom. I reluctantly agreed to a damp survey via the managing agent, and the results were exactly as expected (lower the ground level outside the entirely unaffected single-storey extension, strip walls of all plaster, another injected DPC, replaster with fleece-lined waterproof boarding etc).
After a lot of toing and froing about heating and opening windows (the damp report did at least blame the mould on condensation) and the use of a large dehumidifier, the mould appears to be in retreat - however, there are still some areas of concern. The most problematic of these is the chimney breast, which has been an issue since the refurbishment - there are now large fluffy salt deposits all around the downstairs fireplace, and I’m not sure how to solve it. It’s gypsum plaster over red brick, the chimney is cowled and isn’t used, roof and lead work is sound - but the adjoining property isn’t part of the original terrace and appears to have its own wall built up to mine, rather than shared, so there is potential for moisture to be there.
I would expect the salt deposits to become less obvious once the house has dried out somewhat, but they’ve been an ongoing issue. Can anyone suggest a course of action, or someone knowledgable in the East Midlands area to inspect?
