Hi
We have an 18th century stone cottage with solid sandstone walls.
We recently had a window replaced in the gable end wall ground floor room.
There had been water ingress from above due to what we presumed was a poorly fitted window whose top edge actually protruded outwards slightly beyond the lintel.
When the new window was fitted by our window installer we took some photos of the area. Damage to the plasterwork is evident on the vertical faces of the window opening.
In addition a rather mysterious area of damp was evident on the cemented area underneath the temporarily-removed interior oak window sill.
This damp has not disappeared since the new window was installed about a month ago from all around the frame internally. I think this damp has got worse during driven rain from a storm, and I noticed a small gap in the new exterior silicone sealant at the right-hand bottom corner in the photo. I have resealed this gap yesterday.
I can’t work out where the water is getting in.
Could it be possible that the damp on the cement of the sill is rising up approx 1.2 metres from the ground? From my observations when the new window was fitted the damp on the cement did not go all the way to where the original frame was fitted. Or Is it more likely to be ingress at window height travelling under the cement near the window and then up to the surface closer to the internal wall face?
This end gable wall has problems- the outside earth level is about 200mm above the ground floor level inside so we have rising damp. There is no simple option to lower this level outside as there is a main drain running below ground on the outside.
Photos attached
Thanks.
Photos attached
Thanks.
