Last autumn we bought a conversion of two stone barns in Devon, with two known damp issues. The surveyor who specialises in old buildings said of them:
1. Gable end wall in first floor bedroom: no obvious cause, may need dry lining with a ventilated space behind
2. Cross wall in living room: minor problem, can leave untreated but monitor for evidence of spreading to nearby joinery. (This was originally an exterior wall but since 1882 has been internal between the two barns. Both walls are random stone ~18 in. thick.)
In both cases the problem is evidenced by flaking of the emulsion paint applied by the previous owners (and in the bedroom also efflorescence through the paint) which has become much worse over the winter.
The conversion was done by the previous owners in 1995 including an injection dpc to the internal wall (but not the gable end). The original contractors have ceased trading once and now want £200 for a re-survey before they will consider a warranty claim. We have been quoted by someone else for a Triton cavity membrane system with plasterboard over steel studding in the bedroom (penetrating damp) and injecting a cream-based dpc and replastering both sides downstairs (rising damp).
I am concerned that upstairs there is no drainage or ventilation proposed for the cavity and this may result in rot to the flooring timbers. Downstairs I am wondering whether a new attempt at a chemical dpc will be any more successful than before and what the alternatives might be. Hacking off and replastering will be extremely disruptive because the underfloor heating manifolds and other plumbing are boxed in on the wall.
We are also considering fitting a whole-house MVHR system and I am wondering if it would be better to do this first and then re-assess the damp?
