I hope someone can help me. I've read the thread on damp but I'm still unsure of what to do about a damp problem we have
We have a porch on the front of the house which has damp on one of the walls. The porch walls are stone, I'm not sure if they have a cavity, and the sides are (sorry about this I didn't put them in) plastic double glazed with a hideous plastic front door. I'm guessing the rain runs down the window and around the sill, and as there no drip channel underneath it runs down onto the wall and through to the inside. My first idea is to run a bead of sealant along the underside of the sill to see if the water drops off it when it runs underneath. We will be hacking the plaster off the inside wall and then I'm unsure of what to do.
I will want to put tongue and groove panelling on that wall (to match the other side which hasn't got any damp) but am wary of covering up and hiding future problems. I there anything else I can do to stop the damp and should I be lime plastering, pink plastering, or leave the wall unplastered and just panel?
I hope the pictures help and thank you in advance.
